Dynamsoft SCM Anywhere Hosted Error when launching RegPkg.exe
Hello. I am using Dynamsoft SCM Anywhere Hosted, and I was trying to enable SCM Anywhere VS Package through my computers running on Windows 7 and Windows Vista.
Then I suddenly got distracted by this error message:
Error occurred while launching""D:Program FilesDynamsoftSCM
Anywhere Hosted ClientRegPkg.exe"".Error Message:The requested
operation requires elevation.
Thanks in advance for anyone who can help me solve this problem.
Answered By 590495 points N/A #139230
If this is the first time this happened when using Dynamsoft SCM Anywhereâ„¢ Hosted, try restarting your computer then try it again. If still nothing happened and you encounter the same error again, check the compatibility of your computer with the application.
Dynamsoft SCM Anywhere™ Hosted works with Windows Server 2003 32-bit and 64-bit Service Pack 1, Windows Server 2008 32-bit and 64-bit, Windows XP 32-bit and 64-bit Service Pack 2, Windows Vista 32-bit and 64-bit Service Pack 1, Windows 7 32-bit and 64-bit, Fedora Linux, Ubuntu Linux, Solaris, and Macintosh OS X 10.3 or higher. The computer should also be installed with Microsoft .NET Framework 3.0 or above, this is required by Dynamsoft SCM Anywhere™ Hosted for Windows. You may visit here  for the complete details about its technical specifications.
You may also try upgrading your present version if you are still using an older one. Download Dynamsoft SCM Anywhereâ„¢ Hosted 2.3
