Hi Experts,
I am looking for study material for e-learning on ibooks author and coding.Please give me where I can find ibooks author and coding.I need a detailed report on ibooks and coding.Thanks.
Caecil Brenta
E-learning ibooks author and coding ?
Hi Caecil,
The website apple.com has a very helpful page about HTML widget creation, a feature supported by iBooks. To open and operate the widget, you need to do the following:
1. Set to “true” the info.plist file of the widget to enable it to function in iBooks.
2. In the HEAD of the HTML file, set widget to load Apple JavaScript.
3. Set widget to initialize with iBooks.
Make sure you complete all three steps for the widget to work. Hope this helps.
Murakami Wyatt
