E-mail automatically forward to another e-mail.
How do I have my Albany Law School e-mail automatically forwarded or redirected to another e-mail address?
Best Answer by Cerezo Pico
Answered By 0 points N/A #116441
To be able to redirect or forward your Albany Law School email, you need to create a redirect rule on your mail client.
Here are the steps to follow:
Login your account using your Outlook Web Access.
Press “Option” which is on the upper right corner.
Press “New”.
On the category “When the message arrives”, choose “Apply to all messages” from the dropdown.
On the category “Do the following”, choose “Redirect the message to…” or “Forward this message to…”.
Press “Select people” and type in the email address to which you are redirecting or forwarding your mail.
Press “OK”.
Give a name to the redirecting rule that you have made.
Press “Save” which is on the lower right corner.
You can try to test if you have done it successfully by sending a test email to your Albany Law School email address but refrain from using the word test on your subject as it may be filtered as spam or junk mail. With the steps above, you should be able to see your test email in the Inbox of your designated email address.
Answered By 5 points N/A #116442
Dear,
You can easily forward your Albany Law School email to another email address. Gmail provides automatically forwarded incoming mail. To forward message automatically you will first click the Gear icon and select setting. Then click the Forwarding tab. From the drop down menu select add new mail address which you like your message forwarded. If you wish, you can send your all mail automatically.
Hope this will solve your problem.
Thank you.
