E-mail not sending from Outlook
Hi Mates,
How can i fix this error message 0x80042108.what is it,in the first place?
Please help me any one..?
regards
Hi Mates,
regards
Hi Sam,
Here's your inquiry about the error message you're getting;
"how can i fix this error message 0x80042108.what is it,in the first place?please help me any one..?"
I have tips on how to fix this error message and suggestions to prevent this from happening.
Troubleshooting steps:
1. Check firewall and antivirus settings, disabling it first.
2. Check settings for POP3 and SMTP settings.
3. Recreate email account, close and re-open email client.
4. Check webmail if you can send and receive email.
5. If everything fails, possible email software issue.
6. You may try using different email client such as Windows Mail, Outlook and or Thunderbird.
7. A referral to Microsoft support is the last resource, contact email client software manufacture ex. Microsoft for more information.
This error message is often caused by Anti-virus and firewall settings that will not allow you to send and receive email due to restrictions and too high security settings. You may also disable your inbound and outbound email protection of your security software because this filtered email messages.
If you have any more questions, feel free to contact us at techyv.com help and support link.
Thank you and best regards.
TechyV technical support
