E-mail system reported an error
I've just got a VM going to test TRIM v7.1 and Office 2010 integration.
Windows 7 x64, TRIM 7.10.1132
In TRIM, I configured the integration as per the screenshots I've attached. (NOTE: I know the Word button is unchecked, but I did check it… more to follow)
However, integration is not working. In Word, if I manage the COM Add-ins via the Add-Ins option, I get an error about the HP TRIM Add-in for Microsoft Office, that says:
Load Behavior: Not loaded. A runtime error occurred during the loading of the COM Add-in: Any suggestion? Thanks.
HP TRIM: Your E-mail system reported an error. MAPI_E_CALL_FAILED>
MAPILogon (simple)
