E PDF To Text Converter can’t convert PDF file
Hi.  I just installed e PDF To Text Converter 2.1 on my desktop for batch processing of PDF files to text files.  I try to convert a PDF file and it gives a "cannot convert file" error.  Why is this so?  I'm on a Windows XP 64 bit SP2 system.
Answered By 5 points N/A #198552
Hope all is well with you. am so sorry to hear that your software does not convert your PDF files to text files. Most probably, there is a corrupt file in the application and this can be resolved by reinstalling the application again. If this does not work, try downloading another application that serves the same purpose. Try using boxoft for a change.
http://www.boxoft.com/pdf-to-text/ This link will direct you to the site where you can download boxoft for free.
