I am playing cricket 2007 for a long time now but nowadays strange thing happening with me.
When I connect my USB GAMEPAD to my PC and load the game,the game doesn't loads,instead a black screen appears.
Any solutions to that?
EA Cricket 2007 not working
Hi Asker,
Will I only have one solution in your problem. It seems that your game was old enough and I know there are some errors in your game. So I suggest replace now your game or you can upload it to new edition in this action you can now play it again. But be sure that you choose the right format in your system. Or your USB was not in a good condition or there something wrong in your USB. So copy your save game and reboot it and do some cleaning process on it. And transfer it again your save game in your USB or replace, buy new USB for your games. This would help.
KevinN
5 points
You said that the problem starts when you connect your USB gamepad. So does it work when you use your keyboard only? Here's what I can suggest short of buying a new game:
Go online to Electronic Arts (EA) website and look for the latest patch to your Cricket 2007 game. Those patches usually contain fixes for bugs and stability issues, performance enhancements, new features, support for additional controller hardware, etc.
Try plugging your gamepad to a different USB port. Try the ports that are directly soldered to the motherboard instead of the front panel. The front panel USB ports are usually prone to wear and tear due to constant use.
Check your USB game pad for any physical damage. Has it gotten wet recently? Are the cables okay? Does it work on other games? Does it work on other computers? If your answer is NO to any of these questions, then you may have a broken gamepad. You can try to fix it but it is usually safer and easier to just replace it.
Hope this helps!
dlanear
5 points
This problem is easy to resolve. Just upgrade your application using the EA site and download the latest update. The application you are using is not configured unless you have installed the updated version of this game. I suggest you to update your application and that's enough to answer you problem.
Hope it helps.
-Dlanear-
