I just downloaded, installed and ran easy drive data recovery.
When the program finished the scan it says I have to pay to fix the affected files?
Is it worth it or should I just try another program?
Is easy drive data recovery worth purchasing?
No matter what data recovery software you choose you should first scan your hard drive or media for the deleted files.
If that software lists the file that were formatted or deleted then you should go for its purchase.
If the SW fails to list your files for recovery then try other brands like Stellar Phoenix, Recuva and Wonder share.
Hello Robert
Most software's use this method. They scan your entire HDD and after they tell you that 200 files are damaged, you must pay in order for the files to be repaired.
I suggest you use this program. If will recover the data in your PC.
And yes, you can purchase this program as it is the best, in my opinion. Power Data Recovery.
You could also try 7 Data Recovery. You have the link below in case the first software does not meet your requirements.
7Data Recovery
I hope you will find this information useful.
Randolph
points
There are many softwares that do the same job. But only a few of them work perfectly and also, trusted.
I recommend you to use any of these recovery tools mentioned in this Techyv article.
Best Windows Data Recovery Softwares and Tips
These are good and also, best. I have been using MiniTool Power Data Recovery and it gave me no trouble at all.
Always be careful before buying any software.
