Rose Smith
Posted on - 11/11/2011
            Hello Guys! I tried to set up network using Easy Network SetUp but an error pop up and say that my printer was not found. The error image is attached. I know I installed my printer successfully that’s why I don’t know why this error keeps pop up every time I set up installation. I already tried it many times but it keeps pop up when going to # 2. Please help me.
Easy Network Setup
The printer was not found.
Please refer to the help for troubleshooting information
Easy network set up printer not found error
Hi Rose Smith!
First step that we need to do is check the hardware condition of the printer, if you printer is capable of scanning, try making of any regular document this will if the scanning and printing mechanism of your printer is working. Next is check the wires. If there is nothing wrong with the printer then we can start troubleshooting on the software.
Now, One of the common cause for ""Printer not found"" error on Windows computers are personal firewall and security software. What we can do about this issue is we can disable the Security Software and Windows Firewalls. Then after those steps, Run the Easy Network SetUp and see if it will detect your printer.
If its doesn't work, we can try this workaround. We can manually add Printer by going to printers and faxes, then Add a printer, click on Add a local printer on Create new port > TCP / IP (your Printers IP address), and just follow the installation wizard."
First check USB cable which properly attach with computer USB port or not. after that try once again.
