Spy Pink
Posted on - 05/30/2020
I got a computer from my friend which he had used only for a few months. I want to find a shortcut to restore the system so that I can use it freshly. How can I do so quickly and without much less effort taken?
Easy shortcut for restoring your system
While using system restore all your computers state is reverted includingsystem files, installed applications, Windows Registry, and system settings. But remember that once you opt to restore your system your previously stored files will get hidden.
To run the restore option you can run simply run the command prompt and type in “rstrui. exe” and press Enter.
The system restore wizard will open immediately and you can follow the instructions to restore your system.
This might take approximately 30 mins or so to restore your system.
