Easy Subtitles Synchronizer shows error
I was using easy subtitle synchronizer and working fine as today I got an error message using this software. You can see the following attached error image and I can’t solve it easily. How can I fix this issue ASAP? Have any idea? Please suggest me with a proper solution. Thanks.
Error reading from file I:ESS_0_9ESS_0_9Easy Subtitle Synchronizer.msi Verify that the file exists and that you can access it.
