Easy to Use burning Software
I want to burn movies and Music into CD’s or DVD’s but I had a hard time on searching what is the best and easy to use software for this.
There are a lot of burning software that has a user friendly interface such as Nero, DVD-flick, CDBurnerXP Pro, ImgBurn, Ashampoo Burning Studio, DeepBurner Free, DVD Decrypter, DVD Shrink and BurnAware.
If you still having a hard time picking which burning tool you would use I recommend the BurnAware this application is one of the fastest and easiest to use just choose the disc you wish to use from the main window, and click “add file” to add the file you want to burn in to CD/DVD and that’s it wait until it finish simple as that.
If you have music files like MP3s and you want to create an audio CD out of these files or simply burn the files on a disc, the easiest tool to use is ImgBurn. With ImgBurn, you can burn CDs, DVDs, HD DVDs, and Blu-ray on your optical drive. For the system requirements, ImgBurn doesn’t have specific requirements.
If your computer has a CD or DVD burner and is able to write at the selected speed, you can use the application. To burn CDs, you need to have a CD writer. To burn DVDs, you need to have a DVD writer. A DVD writer is capable of burning CDs and DVDs.
To burn Blu-ray, you need to have a Blu-ray writer and at the moment, it is very expensive. With a Blu-ray writer, you can burn CDs, DVDs, and Blu-ray discs.
