Easy way to do php PDF html conversion
Hello I have some files to be added to our newly launched website. I'm using PHP to convert it. The text contents were extracted successfully, but I have some problem with the images. I should be able to put the picture together with their captions. But when I extract both the file, only the caption appears. Is there an easy way to do a php pdf html conversion? I'm running out of time. Big thanks..
