I need to create a staff assignment excel sheet format. Where can I get it for free. Please give me a easiest way to get it for free.
Easy way to get staff assignment excel format.
If you have access to a PC with Microsoft Office installed on it, then you can create it very easily after launching the Excel program from the Office bundle. Since it is about staff assignments, I can see that at least 3 columns are required in the Excel sheet; Staff Name, Staff ID; Assignment Description, Date Assigned; and Date Due. Here, each row corresponds to a particular assignment for a particular staff. If a staff is assigned with multiple assignments to complete then it is possible to have multiple rows for a single staff, each corresponding to a single assignment of that staff.
For your convenience, I am attaching a template. Please feel free to modify and use it.
Hope it helps.
Best Regards,
Parisi
You will need to install it on your computer and customize it.. Choose any package and I would suggest you use windows Xp sp 3 or later for better performance. You can then go ahead and input and manage the data that you want to.
Thanks I hope this helps you out.
Amos Marie
