An easy way to Nokia E72 optimize
Hello expert, I am using Nokia E72 mobile. I need to optimize the effectiveness of my phone. How can I do it? Please can you suggest me an easy way to E72 optimize for mobile?
Hello Hope you will be fine.
By reviewing your problem.I am suggesting you some points, follow them.
(1) First download this java app it will thoroughly check your mobiles memory utilization(x-plore)
(2) Try to format your memory card(keep your valuable data backup first).Clean your memory cardÂ
by nokia ccleaner software.
(3) Try to avoid to connect your mobile via bluetooth or to pc, it sometime decreases the lifetime and performance too.
(4) You should keep the number of messages and emails low.It affect performance.Â
Thanx
