Unable to install a new game as it says error code 0x800736b1 which didn’t happen before for the same setup file.
While I was installing my new game on the upgraded OS Windows 10 the error came up while setting up. How to solve error 0x800736b1 on Windows 10.
Easy Ways To Fix Error 0x800736b1 In Win 7/8/10
The error code 0x800736b1 is a result of missing registry keys or DLL files that are missing or have misconfigured with the system files leading to corrupt or broken system files.
There is nothing to worry about this error as it is very simple to resolve.
The solution methods are-
Method1: Restore your PC
- Click Start button -> Programs -> Accessories -> Tools -> System Restore option from the menu
- Select “Restore my PC to Previous Settings” -> Next
- Out of various restore dates, select the latest dated option
- Confirm your selection -> Select Next
- Once the PC restores, restart
Method2: Run a SCAN Command
- With the inbuilt SFC command, check for corrupted windows files.
- Hit “Win+R” keys together or open RUN
- Type cmd and hit enter
- Type “SFC /SCANNOW” without quotes and hit enter, the auto scan for corrupt files begins here.
- Follow the instructions given.
Method3: Auto Fixing Method
There are several tools for auto fixing of dll files to fix registry. Install any of them and fix your registry by provided tools. The top list includes-
- RegistryCleanerKit
- Ashampoo WinOptimizer
- Registry Reviver
- Registry Tuner
- PC Repair Tool
- SmartPCFixer
If the error appeared when you are installing the game, make sure the game is compatible with your computer. A game is just like any other application. Before you install it, you need to check if it is compatible with your machine otherwise don’t bother downloading it. If you downloaded the game, try visiting the website again and check its system specifications.
If the game doesn’t support your operating system, you cannot install it. Just try a different game instead. If the game supports your operating system but it requires a much higher Service Pack, update your operating system to the latest Service Pack. To update your Service Pack, download one of the following Microsoft Service Packs for your operating system:
- Windows XP Service Pack 3 – this download is for Microsoft Windows XP. This is the latest and last Service Pack update for Microsoft Windows XP.
- Windows Vista Service Pack 2 – this download is for Microsoft Windows Vista. This is the latest and last Service Pack update for Microsoft Windows Vista.
- Windows 7 Service Pack 1 – this download is for Microsoft Windows 7. This is the latest and only Service Pack update for Microsoft Windows 7.
