ECAuditTool application, an error occurred during the installation
Today, I was installing eCAuditTool application setup but an error occurred during the installation. The error is showing “Setup cannot continue until all system components have been successfully installed”. I think one of the components could not install for this application and installation stopped with this weird message. I extremely need an expert’s advice.
Thanks in advance.
An error occurred while installing system components for eCAuditTool.exe. application. Setup cannot continue until all system components have been successfully installed.
Component.NET framework 3.5 has failed to install with the following error message. Fatal error during installation
The following components failed to install:
.NET framework 3.5
See the setup log file located at
C:DOCUME~1DONSCO~1.DONLOCALS~TempVSDAD.tmpinstall log for more information.
