Eclipse activiti Plugin designer missing devices
Hi there.  I have already set Eclipse preferences in my proxy server.  I'm trying to install Eclipse Activiti plugin Designer latest version but there are a lot of missing devices.  Will there be an AD/LDAP integration?  Please help.  Thanks.
Best Answer by vishwa
Answered By 55 points N/A #173185
Hello Christopher M Davis,
Yes you can have the integration all you need is to do the below steps to get the integration of the system. You have to launch the eclipse after that you have to go to help bar and install new Software.
In the available software you have to work with.
http://directory.apache.org/studio/update/2.x/
Go to the input menu and you have to select add and after that give there a name.
Now you have to click Next and after completing you have to restart it and you can get integration there.
Answered By 0 points N/A #173186
Hello Christopher M. Davis.
Yes of course,you can install the plugin safety.So i'll give the steps to solve your problem.Now open the program,then follow these steps.
1.Go to the help menu.
2.Click install new software.
3.In the available software you have to work with
http://archive.apache.org/dist/directory/studio/update/1.x/plugins/
4.After loaded you can see the available software.Then click Apache directory studio LDAP browser” and click Next
5.calculation of dependencies taken place,Now you will need to and click Next.
6.Now the installation progress start,after the installation progress finished you should restart Eclipse then you can use the LDAP Browser.
7.Now your problem was solved.
