I was using Eclipse perfectly using Mac Operating System but today I tried to open this program I got the following error message. How can I fix this? Have any suggestion? Please share the best solution to solve this weird error message. Thanks in advance.
Eclipse
An error has occurred.
See the log file
/Users/smcho/refvalidator/refactorer/configuration/1358364478360.log.
Eclipse error on mac operating system
Please view this log file and tell what is written in the log file.After that only the error can be detected
The log file will be placed in /Users/smcho/refvalidator/refactorer/configuration/1358364478360.log location just paste the link in the address bar of my computer and view the log file.
I would request you to run the program in administrators mode and check if the following error occurs or not,If it occurs please let me know
Referring to the path in the error message, there must be something wrong with the configuration of the program that’s why an error was caught on startup. If you still have its installer, uninstall the program and then install it again. This should fix any corrupt files on the program. See if this works.
Also, if you upgraded your operating system, you need to check if your current version of Eclipse supports your current operating system. Since you did not mention what version it is you are using, try checking your program’s system requirements from its home page. You may also try installing the latest version of the program you are using.
Visit Eclipse Home Page and download the latest version of your application.
