Eclipse Error in running SW3D as applications on Windows Vista Basic
Hello again, experts!
I have tried to compile and run Sweet Home 3D version 1.6 and 1.7 but I want to do it using Eclipse. I have a plan and I need to do some checking on the software.
In Eclipse, I can compile SW3D on Windows Vista Basic 32-bit operating system. However, when I want to run them as applications, I get the following errors:
20-Mar-2009 12:26:37 PMÂ javax.media.j3d.NativePipeline getSupportedOglVendor SEVERE: java.lang.UnsatisfiedLinkError: no j3dcore-ogl-chk in java.library.path Exception in thread "Thread-2" java.lang.UnsatisfiedLinkError: no j3dcore-d3d in java.library.path at java.lang.ClassLoader.loadLibrary(Unknown Source) at java.lang.Runtime.loadLibrary0(Unknown Source) at java.lang.System.loadLibrary(Unknown Source) at javax.media.j3d.NativePipeline$1.run(NativePipeline.java:231) at java.security.AccessController.doPrivileged(Native Method) at javax.media.j3d.NativePipeline.loadLibrary(NativePipeline.java:200) at javax.media.j3d.NativePipeline.loadLibraries(NativePipeline.java:157) at javax.media.j3d.MasterControl.loadLibraries(MasterControl.java:987) at javax.media.j3d.VirtualUniverse.<clinit>(VirtualUniverse.java:299) at javax.media.j3d.Canvas3D.<clinit>(Canvas3D.java:3881) at com.microcrowd.loader.java3d.max3ds.Main.init(Main.java:121) at com.sun.j3d.utils.applet.MainFrame.run(MainFrame.java:267) at java.lang.Thread.run(Unknown Source)
I also tried to add the dll files in lib/windows since it's a class directory but it doesn't work. Moreover, I have used Ubuntu 8.10 in its place and Eclipse gives me four error messages, which stop it from compiling.
These errors are:
1. JEditorPane.W3C_LENGTH_UNITS cannot be resolved – HelpPane.java line 23
2. PrintMode cannot be resolved – FurnitureTable.java – line 437
3. The method setLocationByPlatform(boolean) is undefined for the type JFrame – HelpPane.java line 385
4. The method setLocationByPlatform(boolean) is undefined for the type JFrame – HomeFramePane.java line 323
I need your help.
Thanks!
