Hi there,
I don’t know why when I came back to Edge Animate it asked if I wanted to use this and reload the composition. I have to click Yes button because I don’t want to lose any unsaved changes. Does anyone know why this appears ? What is wrong ?
Regards !
File changed
TwitterAPlnew.html was changed outside of Edge Animate.
Do you want to reload the composition?
You will lose any unsaved changes.
Edge animate reload the composition unexpectedly
Adobe Edge Animate is a web interaction design tool that lets you bring animated content to websites utilizing web standards such as HTML5. Within Edge Animate, you can apply instinctive timeline interface to visually build convincing HTML5 animations that play back when viewed on modern web browsers.
If you are new to Adobe Edge Animate and want to discover quite a few projects that deal with Edge Animate, you can visit Adobe Edge Animate CC to know how Edge Animate works. For a little tutorial that might help you with Edge Animate, go to Adobe Muse Add Animated Content.
Note: according to Adobe, Edge Animate has already been discontinued as of November 2015 and is no longer being actively developed. Because of this, users who are Creative Cloud subscribers that has a paid All Apps membership are the only ones allowed to download and install applications that are no longer in development. These applications are not available to users with trial membership.
