Hello Techyv Experts,
I need to edit contrast in bulk of images, how can it be done using Microsoft Picture Editor,
Please explain the step by step procedure, all image contrast need to be fixed to same.
Thanks,
Archer Schleifer
Edit contrast in bulk of images
Hello Archer,
You can edit all your pictures o Microsoft Office Picture Manager by doing the following:
1. Select all the images that you want to edit inside the Edit Pictures pane.
2. Adjust the brightness and contrast by changing the setting in the task pane.
3. To save the edited versions of your images, use Save or Save All. To save the images under a different name, file type or location click Save As
I hope it helped.
Osborne Percival
