Good day. I’ve transferred some data from direct server to server FTP client. After doing so, my supervisor informed some data needed to be adjusted and edited, which I did. My question is, do I need to transfer the edited files again from direct server to server FTP client or is it automatically edited?
Edit from direct server to server FTP client
If you used an online editor to adjust/edit your file then you don't have to send it again to the FTP server. You can check the file saved on the server is the edited version by opening the document/file and look for the changes you have made.
However, if you edited the document by opening the file that was saved on your computer and then edited the document, then you have to send it again and replace the file that was previously saved on the server. Make sure the file name and extension are the same, and the FTP client will ask you if you want to replace the file, click yes.
