Edit tags in multiple xml files
I am using xml and looking for edit tags in multiple xml files. Please suggest me XML tags tutorial / Websites. Thanks in advance.
Best regards.
Best regards.
Hi Donald Hammond,
I have read your post and I have made a brief research so that I can give a good solution with your problem.
it may not directly tell about how to edit the tag in xml but it may be helpful for you. Kindly check the links below.
Techrepublic Blog: tips for using word as a XML Editor
Hope that it would help you.
Thanks and more powers.
Notifications
