Gary Jamie
Posted on - 02/07/2013
Hi all,
I'm having a problem with the countdown gadget in the Google sidebar. I can't seem to edit the google sidebar countdown or even delete it. I don't see any function to do that. Is this a bug or perhaps a missing function from my account? Or perhaps a function hidden somewhere. Someone show me the way please thanks!
Editing Google sidebar countdown possible?
Hi dear,
I had the same problem on the Google site. So I managed with it by signing in Google as owner account. If you have a Google account then you can easily edit the countdown counter in Google. You can also create and delete objects. If you want to delete /edit it then follow these steps.
1. Go to “edit sidebar”
2. Go to “more action”
3. Then go to “manage site” and after then go to “site layout”.
4. You will see the countdown gadget listed.
5. Click on “edit” if you want to change then date or title.
6. Click on “delete” if you want to remove it.
Hope this will help you.
