Editing job experience certificate PDF file
An employee is going to leave my company and he needs experience certificate. I made it in PDF format. But there is one mistake. What tool is used to edit the job experience certificate file?
You might want to try one of the following solutions.
Solution 1: You can use a tool for editing PDF files like Foxit Advanced PDF Editor. It is not free, but you may download the trial version if it is only for one time use.
https://www.foxitsoftware.com/pdf-editor/
Solution 2: convert the PDF into document. You can use an online converter (the link that I posted below). It is easy and free to use. You just have to select the file that you want to convert and write your email address so you can download it from there. After converting it, you can edit the file and then convert it to PDF afterwards.
Hope this helps. Good luck!
I think for your case, you should convert the .pdf file to .doc using this: https://www.pdftoword.com
Step 1 : Click the choose file button and select the file that you wish to be converted to.
Step 2: Type your email address and when the file has been converted, the .doc file will be sent to your email.
Step 3: Type the captcha shown in the image and click the "Convert to Word" button.
(This will prompt you, notifying you that the conversion of the file is still going on)
Step 4: Check your email and download the attachment with the .doc file.
Step 5: Open the .doc file and make some revisions.
Step 6: After the revision, download Nitro PDF Reader and Writer from: https://www.gonitro.com/pdf-reader and install. Once installed, initiate the program. Click the Create From File button.
Step 7: Choose the modified document that you have finished editing by clicking Browse. After choosing the file, choose from the Make PDF File options if what will be the outcome of your pdf file. Is it ready to be printed? Then choose the Print Ready option.
This will pop-up when the conversion is progressing)
Now, you're .pdf file is already edited.
Hope this helps you.
Mauricio P.
Moomau12
Thanks to both of you and I am pleased with your solutions. Moomau12, your solution is excellent. The link and screenshot images you provided are very helpful. I want an online converter, which is free and easy to use. After downloading, I found out that the tool can also be used to edit the job experience certificate file. Also, thanks to techyv.com for sharing this solution.
