Mia Molly
20 points
Posted on - 12/21/2017
Fonts, style and so on can be edited in a PDF file. This is done by using a language called LaTeX which is a command based language. Without the use of this language, how can one be able to do editing text in online in the PDF?
Editing Text In Online In The PDF
A PDF stands for Portable Document Format. It is the format of a file which is used in the presentation of documents in a way which is free from any kind of applications or hardware or operating systems. One can be able to do editing text in online in the PDF in the following way:
• Acrobat Reader is used for reading the files in the PDF format. Open the desired file in this.
• Select Edit PDF option present on the right side of the window.
• Choose the text you which you want to modify. Then Acrobat immediately opens the tools that can be used for the editing.
• By using the options present we can successfully edit the file according to our requirement.
