How effect can one use the Google Earth Flight Simulator? In order words, what are the steps to follow to make sure of an effective use of the Google Earth Flight Simulator? What are the detailed and significant features of this application software? What is the name of the developer of the software and may I know how it came about? Thank you.
An Effect Use Of The Google Earth Flight Simulator
First of all you need to install Google earth, You can download it from here, Then install the Google earth app on your computer, And launch it, You can Access The flight simulator by pressing Control+Alt+A, Control+A, or Command+Option+A, Then press Enter, The flight simulator should be activated, If not, Head to tools in toolbar, And select flight simulator,
A window will appear allowing you to choose the airplane you desire to fly, Airport,You want to fly your plane from, The SR22 is easier to fly, So, Choose it for your first flight, And click fly.
The developer of flight simulator is Google, As you know, It is not standalone app, It is a feature found inside Google Earth.
