Effectively switch tabs and browsers
Aside from using the mouse, what keyboard shortcuts are used to switch from one browser tab to another?
Switching one tab to another using shortcut keys is very useful. It will help you to browse and switch to one tab to another easily. I have shortcut keys listed below. I hope that it will help you and find the answer that you are looking for. I also include additional shortcut keys that I think it will be useful for browsing.
These are the list of shortcut keys on how to switch from one browser tab to another.This are the list of shortcut keys on how to switch from one browser tab to another.
Mozilla Firefox
 Shortcut Keys |
 CTRL + Tab |
 It will switch to the next tab. |
 CTRL + Shift + Tab |
 It will switch to the previous tab. |
 CTRL + (1-9) |
 It will switch to your 1st, 2nd, 3rd to 9th tab. |
 CTRL + 0 |
 It will switch to the 10th tab. |
Google Chrome
Shortcut Keys |
 CTRL + Tab or CTRL + Page Down |
 Allow you to switch to the next tab. |
 CTRL + Shift + Tab or CTRL + Page Down |
 Allow you to switch to the previous tab. |
 CTRL + (1-9) |
 Allow you to switch to the specific tab number. |
Internet ExplorerÂ
Shortcut Keys |
 CTRL + Tab or CTRL + Shift + Tab |
 To switch from current tab to the next tab. |
 CTRL + (1-9) |
 To switch to the specific tab number. |
Additional Shortcut Keys
Mozilla Firefox
Shortcut Keys |
 CTRL + N |
 To open a new window. |
 CTRL + T |
 To open a new tab. |
 CTRL + W |
 To close the current window or tab. |
CTRL + R |
To refresh the webpage. |
 Esc |
 To stop the webpage from loading. |
 Alt + Arrow left |
 To go back to the previous web page. |
 Alt + Arrow Right |
 Go forward to the webpage that you visit. |
 Alt + Home |
 To go to the Homepage of your browser. |
Google Chrome
Shortcut Keys |
 CTRL + F4 |
 It will close the current tab. |
 CTRL + Shift + T |
 It will allow you to reopen the last tab that you closed. |
 CTRL + W |
 It will close the current tab or pop up window. |
 Alt + Home |
 It will go to homepage of your browser. |
 CTRL + J |
 It will open the download tab. |
 CTRL + H |
 It will open the browsing history. |
 CTRL + T |
 It will open a new tab in your browser. |
 CTRL + B |
 It will toggle bookmarks display. |
 CTRL + D |
 It will bookmark the current page. |
 CTRL + F |
 It will open the ‘find in page’ dialog box. |
 CTRL + O |
 It will open a file in the browser. |
 CTRL + P |
 It will print the current page. |
 CTRL + W |
 To view the source code. |
 CTRL + F5 |
 It will reload the current page, overriding the cache. |
Hey!
Your question is very important because shortcuts with in the browser are very useful when sometimes input devices like mouse or etc. don't work.
Mozilla Firefox has many shortcuts but to switch between the tab ctrl+tab key is used. This key will also work on browsers like Google Chrome and Internet Explorer. You can also use following short cut keys to work on Mozilla
1) Alt + home =GOTO HOME PAGE
2) Alt + leftarrow =Back a page
3) Backspace =Back a page
4) Alt + rightarrow = Forward a page
5) F5 = Refresh a page.
6) F11 = For full screen mode.
7) Esc = Stop downloading a webpage.
8) Ctrl + (- or +) = To zoom the page.
9) Ctrl + Enter = quickly complete an address.
10) Shift + Enter  =Complete a .net instead of a .com address.
11) Spacebar = Moves down a page at a time.
These are some shortcuts that a user requires while browsing.
Hope you have got the perfect solution for your question.
Thank you.Â
If its about switching from one browser tab to another tab only, all you have to do is press and hold the CTRL key, preferably the one at the bottom left of the keyboard, then tap the TAB key.
To return to your previous tab, press and hold the CTRL and the SHIFT keys, then tap the TAB key.
Open links in a new tab in the background CTRL while clicking the link.
Open links in a new tab in the foreground CTRL+SHIFT while clicking the link.
Open a new tab in the foreground CTRL+T or double-click an empty space on the tab row.
Open a copy the current tab in a new tab in Internet Explorer 8 CTRL+K
Switch between tabs CTRL+TAB to move forward or CTRL+SHIFT+TAB to move backward and CTRL+1-2-3-4-5 to switch from one to another
Close the current tab (or the current window when there are no open tabs) CTRL+W or ALT+F4
Open a new tab in the foreground from the Address bar ALT+ENTER
Switch to a specific tab number CTRL+n (where n is a number between 1 and 8)
Switch to the last tab CTRL+9
Close all tabs except for the one you're viewing CTRL+ALT+F4
Open Quick Tabs (thumbnail view) CTRL+Q
Source Tabbed browsing in Internet Explorer 8
