Henrietta
Posted on - 11/18/2011
Is Scan*Safe Service more efficient than any other else? I plan to install an appliance, like a gateway product. Is it more safe to use Scan*Safe Service and spyware applications to detect virus in my computer? If a Scan*Safe Service is successfully installed in my computer, what happens when it detects a virus? What should I do if ever it detected a virus?
Efficiency of Scan*Safe Service in detecting virus
It is quite efficient with anything related to Web Security. And it is also quite on par with the mainstream antivirus products such as Norton, ESET, etc. If you are referring to the ScanSafe software that is the support Antivirus of Cisco, then yes it is quite safe to use and apply. When it detects a virus, depending on the level of the virus are the options you can get. If it is a sever malware, it has the option to delete the virus. For small time viruses, it has also the option to block it, delete it or keep the virus and store its information at their data bank. If it ever detects a virus, I recommend you delete it. But use your own judgment, if it is a system file; do not delete it unless you recognized it as virus without affecting the system file.
Yes, San*Safe Service is more proficient because of its  very highly performance which is really you can depend on. Scan Safe services are engineered to secure Web Traffic . It has its Scans Safe Web Security that combines Web Filtering with Outbreak engine that works dynamically, very velocious and hypersonically impressive. Outbreak Intelligence is really proven to stop 20% more malware than signature based solutions. Web Filtering produces integrated bi-directional policy.
This helps limit, legal liability, enhance user productivity and save network bandwidth as well as help enforce compliance for confidential data. It has High performance, secure Web access enabled by multi-talent infrastructure. It prevent malware that is attempting to steal your confidential data. It is Proactive, in the cloud protection against zero-day threats. Granular reporting to resolve users that are infected by malware or are at risk.
