Efilive with windows 7 starter on netbook
Hey everyone,
Is running evolving with Windows 7 starter on a netbook ok to do performance wise? I know it runs fine with Windows 7 ultimate edition but I was not sure about Windows 7 starter edition.
Hey everyone,
Hi Tony,
Evolve is compatible with Windows XP, Windows 7, and Vista. It doesn't matter whatever platform you have in your Windows 7 because it is working fine in any Windows 7 platform but when you install it will give you a prompt that the installation did not complete all you have to do is select "Confirm" and this is working fine. You can download EFILive 7.5 in this link: for frees then just follow the instruction given when you double click the setup.
