Electronic email fax server hardware in non-winmodem
I need to find electronic email fax server hardware to find a non-winmodem to set-up fax services under Windows 2008 R2. It has to be a hardware based modem since 2 of them are going into the system. I had read that 2 winmodems in one system will cause issues with fax services. I need modem capable of handling 2 phone lines for two fax numbers. I see a lot of modems out there, but none of them specify if they are hardware or software based. Thank you in advance.
