Jamie Lynn
Posted on - 11/08/2011
I have switched my OS to Mac from Windows. I am looking for suggestions for the e-mail programs to be used. I am using three e-mail accounts which were set up with mail application, and I found the application as not so good since it doesn’t have some necessary options. So please suggest any good e-mail applications.
Email applications cannot be used.
Hello Jamie Lynn,
The first email account I will suggest that you use is outlook express. Download from the internet a version that is meant to be used on the mac operating system. It should be free on the internet, and make sure you do not confuse ms outlook which is for windows with outlook express which should run on a number of platforms.
You can also try zimbra, and outlook exchange though I am not so sure if there are mac versions for these two. But I suspect there are there. Just try looking them up on the internet.
__
Regards
Mahesh Babu
