Email Error 421 with Internet security 2011…..
I get an occasional email error message when sending an email, saying "Email Error 421 – could not send – try again later."
I can help you with the issue on your computer. I suggest you to check the following on your computer.
> Make sure your computer’s date and time is correct.
> Since you have tried turning off the Email scanning and it did not help, try disabling the Norton Antivirus for 15 minutes from the task bar and try sending the mail.
> Also, please check whether the Outlook application has been configured correctly.
> If this does not help you, try updating your Norton Internet Security to the latest version.
> You can update to the latest version without making any additional payment.
> To download the latest version of Norton Internet Security, visit the link http://buy-download.norton.com/downloads/2013/20.4/NISNAV/US/NIS-ESD-NODEFS-20-4-EN.exe
> Download and install the application and it will automatically sync your product key.
> Now, you’ll be able to send mails with Outlook applications.
Thanks and regards,
Skarbos Jay.
