Email Fact Gmail and Yahoo mail
What's the best Email Servers that a user can use to suffices his/her needs e.g. bulk file sending and at the same time security privacy?
One strong advantage that Gmail has over Yahoo mail is that it allows you to send instant messages to your contacts that are online quickly and easily. One strong advantage that Gmail has is that it allows you to send instant messages to your contacts that are online quickly and easily. Gmail allows up to 20mb on its free version
Dear,
If you are comparing Gmail and Yahoo Mail then both have the same size of 25 Mb. The most secure and fast is Gmail as compare to Yahoo Mail. So I will recommend Gmail instead of using yahoo Mail.
Gmail, Yahoo, Hotmail, AOL and Microsoft outlook have limited size of sending and receiving emails which is not above 25 Mb. So if you need to send bulk file (heavy files) to the recipient you must try something else quite similar to the e-mail facility.
There is a service available which is known as 'Mail Big File'. It is very easy and secure to use. You have to upload the file which will be stored online. You will mention the recipient and he/she will receive and email containing the link of the file and file can be downloaded by clicking that link. You can view the service on the below link:
https://www.mailbigfile.com/how-mbf-works/
Similar service is also provided by the following link:
On the other hand if you want to send the files to many users. For instance to 1000 people by one click. Please use e-mail marketing softwares. Find the link below for reference.
