I want to have an embed html codes for chat online found on my website so I can have my site users attach my chat window to their pages.
I don’t know how to do it.
Can you share some examples how to add an embed button with pop-up for the same html codes to generate for them to copy.
Thanks!
Embed button with html codes for chat online
Hi Richard,
You can use websites like Chatwing which allows you to create and personalize a Chat box that you could use easily for your website so visitors can chat as guests or even log in using Facebook or twitter accounts and they’ll provide you with the embed code so others could use it on their websites too.
But if you already have the chat box and Looking for a way to create embed code for it, then RSS (Really Simply Syndication) is pretty much what you’re looking for.
You might want to take a look at this website: RSS FEED to help you create an RSS embed code for your website or widgets.
Good luck
What you want is to embed an html code for chat box so that every time a user logs into your website, it will automatically pop-up, right? Honestly, there are many ways to do this but it depends on your website.
I mean, Wordpress has its own way of making it easy to embed a chat box window. Ustream also has it.
So your web host must have it also.
First, log in to your website and go to your dashboard. Look for some buttons or settings that allow you to put your html chat box codes so that it will be visible to the users.
In the meantime, below are some codes that might be helpful to you. If you are familiar with html codes, then it won`t be hard for you to understand and edit. These two codes are generated by ParaChat Room Code Generator.
Embedded Chat Room: Attached code
You can make your own chat online and customize it
http://www.parachat.com/personal/basic/create.php
You can choose your options after generating the code when you finish designing in there creating tool:
Option 1: Embedded Room Code (recommended)
This code is directly into the HTML source code in your webpage, so if you want to add more design it can affect your webpage positioning.
Option 2: Pop-up Room Code
This codes launches new browser window when clicking the link and it has an embedded "Chat Now" image.
Option 3: HTML Text Link Code
This codes launches new browser window when clicking the link and it has an embedded "My Chat Room" image.
Option 4: Standard Link (URL)
This link will redirect to your parachat room webpage, this is the best option if you don't have any website.
