EMCO Ping Monitor Free 4.7.3
I have got the news of release of EMCO Ping Monitor Free 4.7.3.
What are the changes made to the previous version of this tool?
Best Answer by Amanda Morson
Answered By 0 points N/A #143810
Hi Nancyhernandyu,
The Ping Monitor is a tool for tracing the connections to hosts under the local network and internet.
New features in the Ping Monitor Free 4.7.3:
  • While monitoring, the pause actions are delayed until the process is set to on again and the status of your connection will be assigned.
  • The pause time will not have effects on the outage time and uptime
  • The entire enabled actions is viewable under the Host Details pane.
  • The On Monitor Start dismiss action will become obsolete and will be removed.
Resolved issues:
  • A potential SQL transaction error while logging
  • The Log structure on the Application is damaged after removing logged events automatically.
  • A potential error on resetting the monitoring statistics
Best Regards,
Amanda Morson
Answered By 10 points N/A #143811
Hello Nancy,
The following are some notable features in the EMCO Ping Monitor that you have mentioned:
  • Connection Monitoring and Statistics: The state of connection to the monitored host is usually detected when regular pings are send to it. In the event that the host does not reply during a particular number of times, then the application detects an outage and after that it will go ahead and update connection status on the main screen.
  • Configurable Event Handlers:· Application will enable you to register any custom handler do that it can be executed when connection to the monitored host will be lost or restored.
  • E-Mail and Tray Notifications: It is possible for you to get notifications about connection state changes and regular reports by different ways.
  • Customizable Application Settings: In case you have got specific requirements for executing of ping operation you can go ahead and change settings to tune up the application.
Carl
