After installing the Empire 3 games on my Dell PC, a “publishing product information” message appears on the screen of which, 10 minutes after, an error message 1935 also appears when in fact it is 99.9% finished. The error message occurs during the installation of the assembly component (303994BA-6487-47AE-AF1D-7AF6088EEBDB) HRESULT: Ox800736FD.
I have tried installing the MSI installer 4.0, but after installing it, the same thing happens. Please help me find a solution for this problem; I got tired of doing it the whole day and, yet, nothing happens.
Please help.
Thank you.
Empire 3 Games Installation Problem
Hello Larken,
To be able to solve your is sure, I recommend you to run an antivirus or SFC scan on your computer to see if there's a corrupt system for your files:
Click start.
And choose all programs.
Right click the Command prompt after you click accessories.
Choose the security tab.
Select run as administrator.
Click the command prompt.
And then type in sfc/scannow.
By doing that process, it will scan and fix all the corrupted system files that are operating. If you done all that and still experiencing the problem, you can go to the link below and ask for support:
http://support.microsoft.com/common/international.aspx?rdpath=4
Zorian
Abbyarc
Hello Larken,
Method 1: Unload and install Microsoft XML Core Services 4.0.
To solve this problem, install the game after you unload and install the most recent version of the service pack of Microsoft XML Core Services (MSXML) 4.0. Microsoft XML Core Services (MSXML) was known like the analyzer XML of Microsoft.
To obtain more information about how unloading the most recent version of the service pack of Microsoft XML Core Services (MSXML) 4.0, visit the following Web place of Microsoft https://msdn.microsoft.com/library/system.xml.aspx.
Method 2: Remove the program of easy installation of Win-tools.
To remove the program of easy installation of Win-tools of the team (equipment) using a program antispyware. If you do not have a program antispyware, be able to unload the program Microsoft Windows AntiSpyware. To unload the program AntiSpyware of Windows, visit the following Web place of Microsoft:
https://www.microsoft.com/en-us/security/default.aspx. After removing the programs antispyware, withdraw the Control panel to the installed programs. Click in the beginning, click in executing, write appwiz.Cpl and, next, click in Accepting. In Windows Dress, click in Beginning.
