EMS sq. manager 2008 for interbase for firebird not importing XML properly.
Ems sq. manager 2008 for inter base for firebird latest version is supposed to import XML formats but mine does not. Is anybody else facing the same problem?
Try the following steps:
Hope this information helps you.
If you are using EMS SQL Manager for InterBase/Firebird 2008, check the Firebird server version that you are using because it may no longer be compatible with your current SQL Manager. Try using EMS SQL Manager for InterBase/Firebird 5.2. As of the moment, this is their latest version. Visit EMS SQL Manager for InterBase/Firebird to download. In this version, Microsoft Windows 7, Windows 8, and Windows 8.1 are now supported.
They also added preliminary support for InterBase 2009 as well as support for EUA or Embedded User Authentication for InterBase 7.5 and higher. It supports activating/deactivating, editing, duplicating, creating, and deleting of new object. If you are using Firebird 2.5, you can now create a view from stored procedure. The issue with InterBase Desktop Edition servers where you cannot establish a connection to a database using the Local protocol was already fixed.
The issue with NTLM authentication where connecting to a host causes an error was already fixed.
