Trevor Jhon
40 points
Posted on - 02/05/2013
Hi Experts,
I am using Emsisoft Anti-Malware which helps in removing Trojans, keyloggers, malware and many other suspicious objects in my Windows XP machine.
I would like to know is Emsisoft Anti-Malware totally compatible with other antivirus and Firewall applications or do I need to uninstall my other antivirus program in order to fully use Emisoft Anti-Malware software?
Is emsisoft anti-malware totally compatible?
Hi Trevor,
There is no two antivirus software that is compatible with each other, so you should uninstall your old one, then install Emsisoft.
Pamela Conley
Hello Trevor,
There is no problem running Anti-Malware software while having other antivirus and Firewall. You can't run two antivirus software at the same time though, because they will see one another as a virus. After that being said, Emsisoft Anti-Malware will have no problem running with another antivirus/Firewall suite.
Hope that this answers your question.
P VhilaryA
