Hi there! I have been browsing some websites through my iPod touch. But sometimes I am forgetting to bookmark those webpages that I need to remember so one way to browse it all again is by searching the history. Is it possible to register iPod touch history? Where can I find its settings?
Thanks for the help.
Enable the Browsing History in iPod Touch
Hello James Rio Allen,
The best way to save is to bookmark it. Try using the bookmark. It is very easy and you wont forget it. Press + sign on the left corner of the address bar.
Hope this helped you.
Hi James Rio Allen,
If you keep on forgetting to bookmark your webpages and you need a browser that saves your history automatically, please install the Opera Mini browser in your Ipod Touch. It is very easy to use and you can download it in your app store for free. You will not be needing to worry if you were not able to bookmark your webpages. Once you open the Opera Mini browser, you can click on the logo on the lower side of the browser and then choose "History." You will see all the History of the webpages that you have browsed using the Opera Mini browser.
Hope this helps.
