Enable Option for Searching Screen Names in MSN Messenger
My searching option for msn messenger screen names has been blocked/stopped working. How can this be activated for searching screen names?
If you suddenly can't search screen names on MSN Messenger, Try to create a dummy screen name and see if that will allow you to search, if you can, that means that you have been blocked by MSN. You will need to get in touch with them to sort the problem and if not, try to uninstall and reinstall you MSN Messenger. That should fix the problem.
Create a dummy screen name and see if that will allow you to search, and if you can search then you have been blocked by MSN, then you must get contact them to sort the problem; and if you can not then try to uninstall and reinstall you MSN Messenger.
