Android is a mobile software which accelerate and increase the ratio of Internet data transferring to the mobile device. My Android has the problem transferring data properly. Any possibility to fix it up?
Enable to speedup GPRS android for mobile network?
Hi Pattrick,
I think there is a solution to your query, the most possible way to fix up the issue you have is to upgrade the android operating system. The problem may most probably be due to your former operating system.
You can also try and check with your service provider to see whether there is an error with the connectivity and try troubleshooting it or change the settings.
I hope this solves your query.
