Can anyone tell me the way of configuring contact email sharepoint? Can I use third party software or, there is any options to configure it manually. Should I install any software? Please help me to figure it.
Enabling contact email SharePoint help.
Hello, Jeana Z Breunig
Hope you are fine.
Obviously there are advantages that you can get from configuring your SharePoint system for incoming and outgoing emails.
For example, if you configure enabling Incoming Email in SharePoint, you can store the messages, attachments sent to other team members into lists, libraries etc.. And for this you do not need to open your SharePoint site and do a manual upload.
 By Outgoing Email enabled alerts, tracking various items in the library, lists, documents can be detected.Learn configuration step by step and with image
Hope you will get your answer.
Hi Jeana,
You could activate or configure a SharePoint 2010 document library for incoming emails in Windows itself.
Steps are:
Make sure to activate SMTP features on the SharePoint Server by making sure to login local server
configuration of incoming email settings  by installing SharePoint central administration
configuration of SharePoint Document library for incoming mails by switching to document library settings.
Hope it will work or you. Thanks.
