Enabling Samsung Galaxy ace chinese character keyboard for input
How can I enable Samsung galaxy ace Chinese character keyboard input on my mobile devise to ensure that a user can read and write using Chinese language?
Dear user,
Yes, there is a way to enable Chinese character keyboard on Samsung Galaxy.
What you need to do is hold on the setting button in the message mode, then select Chinese IME input from the three options shown which are Swype, Samsung Qwerty and Chinese IME input. It will definitely work.
Hope this will help you.
Thank you.
Hello Chloe Victoriay,
I will suggest you an application which will enable you to read and write text messages in Chinese Language.
Please go to the Google Play store and download an application named "Swift Key". It has a wide range of language packs along with that it has swipe feature and different themes for keyboard input and much more.
Try it out I hope you like it, here is a download link:
