Enabling server to send email from Microsoft Frontpage
Hi everyone
I have created a form using Microsoft Front page.Â
How can i enable my server to send  email when using Microsoft Front page Forms.
Help would be appreciated!
Thanks
Hi everyone
Thanks
Hello Adolfo,
You must require to configure the Front Page Server Extensions to send email so that you could send email from a Front Page form,
Do the following in Internet Information Server (IIS):
1.   Locate the properties by right-clicking on your website and then select properties.
2.   Properties>Server Extensions tab.
In Front Page 2002/2003, do the following:
Click on Settings.
Your browser will run and the Change Configuration Settings web-based administration form will come into view.
Enter in your SMTP mail server and the email address that will come into view as the Form and Reply To addresses when a form is submitted, and then, Click Submit.
Hope this was helps
