Hi guys,
I have installed windows 7 on my system. Recently I installed DVD shrink on my PC for taking backup of some of my disks. The software was installed successfully but when I try to take backup of a disk, it won't let me do it.
The encoding process starts successfully but it gets stuck at 91%. It is only happening for one particular disk. All other are working perfectly fine. I am using the 3.2.0.15 version of DVD shrink. The screenshots of encoding stuck at 91% are attached below:
91% Encoding
Enable Video Preview
Decryption Statue: Â Â Â Â Â Â Â Â Â Â Â Â Not Encrypted
Rate: Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 13,714 KB/s
Buffered: Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 16 MB
Time Remaining: Â Â Â Â Â Â Â Â Â Â Â Â Â 24 seconds
                               Pause          Cancel
DVD Shrink 3.2
DVD Shrink encountered an error and cannot continue.
Failed to read file "D:"
Data error (cyclic redundancy check).
                                 OK
I don’t know what to do next. Does it has something to do with the version of the software because the version I am using is 2004 version which is I think quite old. Has it been updated or not, I didn’t find any information regarding this.
If anyone has any information, please shed some light on this issue. I'll be really thankful to you all.
Waiting for your replies.
Encoding problem with DVD shrink
Hi there Gloria:
Thanks for trusting us regarding this/your issue/problem. DVD Shrink is no longer supported the version. You're right, it has something to do with the software version. The version you have now is not the latest one. It won't work on any modern disk my dear.
You can visit below site for more concern. I hope this will help you.
https://www.alexa.com/siteinfo/softpedia.com
Hi Gloriawburbage
Every time you will find this error because of a structural protection. Which DVD shrink does not recognize.Â
The Files you are trying to encrypting, it could be possible that the particular disk have that kind of protected stuff that’s why you got an errorÂ
Here is a simple and tricky way to get off from this problem.Â
First of all you should need to rip the DVD to your Hard Disk by using anydvdripper via rip video DVD to hard disk.Â
After doing this now import your files from hard disk to DVD shrinkÂ
Encrypt that files again, It'll work fine this time
I hope it’ll resolve your problem
Johnstoon Leen
Hi guys, I'm thankful to all of you. All of your solutions were very helpful. Johnstoon Leen, your comment was perfect for me because your explanation helped me to understand why this problem is happening, and also informed me of a simple way I could fix it. Your step-by-step instructions are very easy to use, and by following them I am now able to overcome this problem. Thank you one more time for giving me this nice remedy.
