Hello
during starting the windows I get the following message frequently:
"There was a problem starting msihsz32.dll
The specified module could not be found"
I did not found any solution about this topic through Google. It may reason for some installed programs or other else, I don’t know.
So I want a solution and please help me.
Thanks in advance.
Encountered problem when starting windows
Hello Chris,
The problem you are having now is the problem i used to face few years back. To solve this problem you only need to download the msihsz32.dll file which is missing from your computer. You can download the missing dll files from this website https://www.dll-files.com/ . After you have downloaded the file just follow the simple steps:
1- Unzip the downloaded dll file and copy the file.
2- Go to Start -> Run -> here type -> C: Windows System32 and paste the file
This will remove the error permanently
Thanks
