Hello Gurus,
It was the first time I encountered such problem with Notepad since I started using it for creating and editing scripts.
I was then saving my edited new script by choosing “Save As”, when the error message below popped up.
Notepad
Common Dialog error (0x3002)
Am I missing something? Is there a workaround here?
Thank you in advance.
Encountered problem while using Notepad as script editor
Try updating your operating system, it must be of late version of the windows and also your operating system needs the ComDlg32.dll file. There is exact description that Microsoft is giving to their customers about this error. But you can also run a system restore or system check to see if there is any damage in your system.
There are also many people experience this problem while running scripts. Hope that you get an idea on what you can try to solve this problem. This is not an exact answer but I hope it helps you with your current problem.
