ace atkins
Posted on - 03/21/2012
Hi experts.
The error messages display those typically encountered while running with DRM protected media. I’ve downloaded a 30 day trial version of DRM protected by Fleetwood Mac track, in WMA format. The error message situated at the upper right displays what I see in Movie Maker 2 when I try to import it.
How to solve it? Help me.
Thanks
Error:
Windows Movie Maker   Â
The file C:Documents and SettingsPapa JohnLocal      Â
SettingsTemporary Internet     Â
FilesContent.IE5BEKBZT41Fleetwood_Mac-Sara_0001[1].wm     Â
a is protected using digital rights management and cannot be     Â
imported.Â
Encountered while running with DRM protected media
Hy,
You got this type of error message for use unsupported video file in your windows movie maker. Currently WMA format file can not support in your installed windows movie maker. You should re install it in your pc for fix this problem. You might be ensuring update and latest version of that software before installs it again. Your current version can not open few file for the restriction of software version. So when you will upgrade it, then you won’t face this type of error message again in your desktop or laptop.
I hope you are understood my point.
Thanks
This error is occurred when you using audio or video which is protected by DRM. These media files cannot be import into windows movie maker.
I suggest you to convert this media file using a software and then import into movie maker.
Download Audials Tunebite software for this. This application can convert DRM media files.
Also you can use avsmedia converter for use this kind of scenario.
